Ipad ddj ergo , cross fader problem IPAD air 4
Hi, I have a problem with my ergo ddj console and ipad air 4 , when I use the cross fader, every time I change direction the headphone light turns on, and it doesn’t work well.
Hi @Tony_Marino,
Thanks for contacting the Algoriddim Support Team.
Please make sure that you do not have Auto Select active in the Advanced djay settings. This will automatically switch the pre-cueing output to the inactive deck for your to pre-listen to the song.
Let me know if the issues persist.
Cheers, G
