Please tell me I don’t have to use cable connected speakers
Hi Robert,
Yes, you can also use bluetooth speakers/headphones with djay. Simply pair your device with your iPad, then select it as output in djay. Tap the gear icon and click on the AirPlay icon next to the master volume slider.
yes ,but when you plug in Spin 2 it stops working {right]? bottom line no pre cueing
while device is hooked to spin2 & Bluetooth speakers???
Algoriddim, I want to thank Warren the rep , for answering my questions about using Spin2 with Djay and playing the output through my Bose Mini Bluetooth speakers. Impossible Right!!!
