Ipad pro 2021 + ddj200 : sync doesn't works well
When i push the sync button, it starts playing the song and the sync doesn’t keep working if you start playing with the cue points.
I had an ipad pro 2016 before and it worked very well…what the issue for this sync pblm?
Hi and welcome to the forum. Go to settings then go to general and try this.
Yes thx you!! Works now!
Great. Really glad I could help
