Stuck in iCloud status initializing
To back up cues etc
I have uninstalled and re logged in used WiFi or iPad data service and nothing
I have the latest updates this is the only thing that never worked for me
I do see my phone is backed up problem is all my cues are in my iPad
The hot cues are saved in the djaymedialibrary file as described above. If you copied this to an external drive or cloud location as I suggested, you simply need to copy it from your backup location back in the Files App, On My iPad, in the djay>User Data folder.
If you have somehow lost the backup that you created earlier then you can likely use the djaymedialibrary that is on your iPhone. Since you were previously using iCloud sync.
Simply open the Files App on your iPhone, navigate to On My iPhone then to djay>User Data.
Copy the djaymedialibrary file here to an external drive or to a location in your iCloud.
Then go back to your iPad and copy this file over the one on your iPad.
If you have a recent full system backup of your iPad on iCloud or in iTunes on your Mac then your should still be fine by doing a system restore on the iPad.
Oh wow. How did you delete your full iCloud system backup of your iPad? Uninstalling djay from your iPad should have no effect on your system wide iCloud backup.
