iPad Pro iOS with FLX10 and Djaypro
Hi folks,
I have bought the FLX10 assuming it would be ok with my iPad and Djay pro and all that happens is that I see the audio is playing through the Flx10 but nothing I press on the mixer works or talks with my iPad.i haven’t played since back in the day using technics 1210s and certainly not with an iPad. I need proper help to get this working please!
First check in the settings whether the controller is recognized at all. Then:
  • Try a different USB adapter
  • Try a different USB cable
  • Try it on another iPad or a computer
  • Try it with a different Flx10 - in other words: maybe the controller is defective.
Hi @Fortissima, when creating new topics, please do not forget to answer the questions in our template with specific details about your setup not just “iPad” or “Latest Version”. This helps all of our community moderators to provide the most effective support to users with the utmost efficiency. Thanks!
  1. Does your iPad have a USB-C socket or a Lightning socket?
  2. Either way, make sure you connect to the FLX10 using your original/genuine Apple cable.
  3. If your iPad has a Lightning socket, you may need to use a genuine Apple Lightning to USB 3 camera adapter: Lightning to USB 3 Camera Adapter - Apple
  4. If you are connected to the USB A socket on the back of the FLX10, make sure you set the switches on the top panel for all for channels to USB A as well.
  5. Have you installed the latest FLX10 firmware from Pioneer?
