I just got a Mixon 4 about 3wks ago and i was excited to use it with my ipad pro. I’m switching from the Numark iDJ pro that I’ve used for the last 8yrs and loved it. For some reason when i connect my iPad the output volume is really really low compared to my computer. Is there a fix for this?
Hi @DJBla5tOff, welcome to the community,
- Please check the Main Volume level at the top of the Settings page.
- Also, can you share a screen shot of your Settings>Audio Devices?
- What iOS and djay Pro versions are you using?
Helped me too thanks
For me, it was the volume of the iPad was turned down.
