Hello, I just bought the iPad Pro 2018 and tried to connect my beatpad 1 controller with an anker adapter to fit in the usb-c port of the iPad Pro but nothing is working. As it’s a native controller of Algoriddim I would please you guys to give me a solution for this problem, tried to google it but didn’t find anything, thanks.
Hello Pierre, I own a Reloop Mixon 4 and a Apple iPad Pro with USB-C port. So I encountered the exact same problem. My solution you need to order a usb-c to usb-b cable. The perfect place is a company called D J Tech Tool, goggle it. The cable is 6ft choice of 5 different colors @ $14.99. Floyd
Thanks Floyd I just bought 2
