If I use the echo effect it ́s scratching, and that sounds cruel, it happens with the iDJ Pro as well with the Ipad 2.
Is that normal?
Is that normal?
Sorry to hear that. What do you mean by “scratching”?
If I turn up the echo hipass effect, that sounds as a speaker is broken.
Sry,
the problem has loosed itself from itself, after the update.
Any fix?
i can see you are not answering.
Maybe we will hear any normal answer about the problem with idj pro and djay effects…
I still have this problem.
All the FXs are dropping down volume
