I struggled for days when my iPad2 wouldn’t connect to my iDJPro and this forum only described people returning their boards to Numark to find no issues. Check your connector port on your iPad. I looked in and found one of the pins mashed up against the back wall of the port. This prevented the ground pin to contact the IDJPro connector and find the device. With a pick, you can straighten out the pin and allow the ground connection to be made. I think the metal IDJPro 30pin connector is a bit aggressive on the iPad port when comparing to most plastic 30pin connector cables.
Hi Colby Buckman,
thank you very much for your help and experience with this issue.
We are always helpful if users are here to help.
It would be great if you could attach a foto o f the pin you are referring to.
Thank you very much.
Hi Colby Buckman,
