iphone 7 + djay pro + spotify
Hi guys ! i would appreciate your help please… i would like to use automix on a playlist from my spotify playlist
Also just automix some playlist i discover… getting a hard time to find how to do that.
thanks for your help
Louis
Hey Louis,
thank you for your post.
In order to select a Spotify playlist in the Automix menu, please select the Spotify library as last used library.
After doing so you can select the preferred Spotify playlist via “Playlists”.
Cheers,Lukas E.
