Is anyone knows how to map this…?
Hi, I’m looking for specific midi mapping for this buttons can find it in : cue point section, beat skip or beat jump (16,32,64)
@Digital_Jedi the MIDI function you’re looking for is called Skip Forward/Backward. You will probably also want to map Skip Duration +/- to a Shift layer of the same buttons so you can adjust the size of the beat jump.
@Slak_Jaw you are great man :pray: thank you.
How many keys or pads do you have available for this? Instead of always setting the beats and then only jumping forwards or backwards, you can also preset the number of desired beats (“Skip x Beats Foreward” or “Skip x Beats Backward”). In my case, I used eight performance pads for this. In practice, however, I have never really had the opportunity to use this - but then everyone works differently :wink:
@Digital_Jedi you’re welcome! Glad that helped.
