Is Djay Pro already compatible with Denon Live 4, just like Virtual DJ which is also integrated?
Hi @Eddy1, welcome to the Community! Yes, this hardware is compatible with djay on macOS, Windows and iOS. It is not compatible with Android. Also, the screen of the SC Live 4 is not currently supported. I hope that helps!
No, I mean that Djay Pro can be integrated in the software of the Denon Live 4, without the need of an external device like Macbook or iPad. Virtual dj can do this.
Thank you for taking the answers seriously.
Hi @Eddy1, thanks for clarifying your question. This is not currently possible. Algoriddim djay needs to run externally on a macOS, iOS or Windows device.
