Is it possible to change the default Media Library location in Djay Pro 2 for Mac?
It defaults to the Music directory, but I want to have it saved in my Dropbox so that it is automatically backed up. Any way to change the default?
At the moment it is not possible to select a location for the djay Media Library.
I added this as a feature request for a location setting.
Thank you in advance.
Hola, tengo el mismo problema. ¿Se sabe si puede cambiar de ubicación?
Ok! Thank you!!
