Your question:
14.7
V 5.2
DDJ SX2
I can’t find the EQ/N button in the MIDI mapping menu. Am I missing something, or is it not possible on my controller? I know they already have a button for this with Reloop controllers. I appreciate any help you can provide.
Hi @Jason_Jaso, welcome to the Community! The MIDI command you’re looking for is called Toggle Neural Mix - EQ. It’s found quite far down in the Neural Mix commands.
I don’t know whether this is the case in this specific instance, but I have noticed once or twice that not all midi options are available in every case.
Hi, Could have sworn I replied, my apologies, Yes, this was solved on the top of the thread. Thank you!
Thanks for the follow up @Jason_Jaso. You’re welcome!
