I want to be able to preview a spotify song that is selected in the library without having to use my mouse to press play. Can’t see the option in the midi implementation
in order to do so you have to map a button of your midi device to the following command with the djay pro midi mapping feature:
Now, if Split Output is activated, the preview of the song plays with one midi-button-click.
I hope this helps to explain things, if you need help accessing the midi learning feature contact us right away.
Thank you in advance,
cheers,
