Can I use the Deejay pro AI audio fx with the DJMS7 mixer?
Hi @Roman,
The DJM-S7 is fully mapped including performance pads.
You can also directly access Neural Mix on a lot of the supported mixers via one of their performance pad modes:
If you’d like to change the default mapping to better fit your needs, you can also do that using djay’s MIDI learn functionality. For more details, please see the following FAQs:
