Is S9 Supported on iPadOS?
is the S9 supported? I do not see it when I select external mixer mode, however some basic functions work such as upfaders and crossfader. I’m unable to output mains of the S9.
iPad os is 16.3.1 amd unit is MXAV2LL/A iPad Pro (12.9-inch) (4th generation)
djay ai is 4.1.6
Hey @stacktrace ,
Thank you for posting regarding this here in the Community.
Just to confirm, are you referring to the Pioneer DJM-S9?
We currently support the following Pioneer controllers natively for iOS:
But you can always map the controller yourself, if you wish, following the steps here:
Hope you will find this information useful. Cheers!
Yes, the S9. It would be great if this device was supported out of the
box, but I can MIDI map it instead.
