Is the Gemini CDMP-7000 a compatible controller for Algoriddim's Djay
Is the Gemini CDMP-7000 a compatible controller for Algoriddim’s Djay
Hey Tyjuane RA,
the CDMP-7000 is not natively supported by djay Pro but you can use the midi learning feature to map the controller, have you tried this feature so far?
Do you have video or information so I can master it
