Is the Numark N4 Controller supported for DJAY FOR MAC Version? Do I have to manually map or will all of the functions work by default.? If I have to manually map, is tis very complicated?
Thanks. I love this Program!
Hi Juan,
Thanks for your support.
No, this controller is not natively supported but you can use it via MIDI learn. Select “Configure…” from the “MIDI” menu to map your controller.
By the way, you can find the list of natively supported controllers here:
http://www.algoriddim.com/djay-mac/ac…
Hello Warren, i use lattest Djay version with NS6 controller, but Djay do not recognice all the functions of the Controller ??? = example the running lights on the Platters are not working ? …how i can download the NS6 mapping with platter-LEDs for Djay or change, that the Platter-lights are running ??? …
