I notice that if I use the keyboard shortcut to reset tempo, it disables sync on the slave deck, which seems trivial but is a deal breaker for using ableton link with ableton Live because the moment I switch decks, ableton Live’s BPM doesn’t get updated (rendering it useless because I can’t be going around double clicking sliders on the downbeat during a set). Am I missing something?
Steps to reproduce the issue are as follows:
Djay Settings:
- Maintain sync on song load: unchecked
- Exit sync on pause, scratch, or cue jump: unchecked
- Two deck mode: enabled
- Crossfader: set to middle
Test steps for shortcut behavior:
- Assign keyboard shortcut to Deck 1 with action “Reset Tempo”
- Load tracks with different tempos on both decks
- Enable sync on both decks, first Deck 2, then Deck 1
- Press the keyboard shortcut to reset tempo on Deck 1
Result: Sync is disabled on Deck 1
Test steps for UI behavior:
- Repeat steps 2 and 3 above
- Double click on Deck 1’s tempo slider
Result: Sync remains enabled
Expected result: The Reset Tempo keyboard shortcut should behave the same way as double clicking the tempo slider and should not disable sync on the slave deck.
