Look above xD
Thanks, margonien
I’m also using the reloop beatpad, would there be a possibility to map the FX picker to the wet/dry knob. Since picking the fx is not really that important for a hardware knob but a wet/dry signal is much more useful is it is mapped to one. Just an idea though.
Hi Margonien,
There’s no wet/dry control on the Beatpad but you can control it directly through the app. Open the FX tools and go to Manual.
If you’re using djay (Pro) for Mac then you can re-map the knob (MIDI > Configure).
