Is there a hold function for the FX section
Is there a hold function/ button for the effects section (FX) or do I need to keep my fingers always on the effect to activate ( specifically in pad mode)? It woul be good to free the fingers for more simultaneous actions. Otherwise big thanks for the great app…it gets better and better.
Thanks, got it.
Hi Touts,
You can use the Manual FX mode. Simply go the Manual FX panel and select “Slider”.
There, you can just turn on the effect and leave it.
