- Device model (e.g. 2020 iPad Air 4th Gen): iPad Pro 5th Gen
- Version of operating system (e.g. macOS 14.4.1): iPad OS 17.4.1
- Version of djay (e.g. 5.1.2): 5.1.6
- Hardware/controllers used (e.g. Reloop Mixon 8 Pro): Reloop Mixon 8 Pro
Your question:
Is here a feature that allows you to load the next song on the playlist? If yes, can I midi map it?
Hi @codebeast, you can do this via MIDI, but not with a single command. You will need to MIDI Map 2 commands:
- Select Next Track
- Load Selected Track
This should also work with one step, at least that’s how it works for me: Target Deck 1 / 2 → Load Next Track. But I have also noticed that not all options are always available, which seems to depend on the connected controller.
