So what I’m used to with my pc software (VDJ 8) is that a track is set to play from a cue point when I hit a hot cue button on my Wego 3. In Djay 2 for my ipad, hitting a hot cue button only makes the track play while the button is depressed or until I hit the play button while simultaneously holding the hot cue. That’s too much work, I just want to be able to hit a cue button and have the track start playing. Is it possible?
Yes you can. But you will have to jailbreak your iPad and edit the wego 3 midi mapping file.
See my post in midi learn for iPad.
