I find myself using Pro AI for single song video production. The problem I have run into is setting up detailed effect chains and precise level settings, like you would on a DAW, and have no way to recall my extensive work product. I feel if you are going to have a lot of amazing features, there is going to eventually be a way to save your exact desktop.
If you can’t do this, this might make a good feature request/
As a sidenote, for your next product I would happily buy midi sync DAW software from Algoriddim.
My dream product is software that integrated Djay with a basic MIDI software sequencer (think Atari ST or Opcode Vision) for hardware, plus a basic version of LIVE… an all-in-one Algoriddim product.
you should probably take a look at this page: Link-enabled music making products | Ableton
I’d wager you have something on that list (ProTools?) and can make what you want to happen with some thought
Thank you for your reply. Will check out that page.
