Is there a way to use a usb with iPad and Rane one
On the weekend l played at a gig and another dj friend of mine asked if he could plug in his usb stick…
I told him it couldn’t be done a# l didn’t have a usb port,
My question to anyone that may know,
Could I get a powered usb hub and plug that into the iPad camera adapter and then plug the Rane one into one of the ports of the usb hub and also plug a usb stick into one of the hub ports?
I guess if that worked I would be able to read the tracks on the usb from the Files folder?
@maurizio_T I just tried this with my USB-C iPad and powered USB-C hub. I was able to see the songs on the USB within the Files app. I was also able to see them within djay through the Files source. I was able to import the tracks, but when I tried to load them into a deck I received an error message and they wouldn’t play. Seems like this should work with some more messing around, but that’s about all the time I’m willing to spend on it.
Thanks,
I might try it out to see if I get the same result,
Is you USB hub A/C powered up?
There was YouTube video that I saw with a guy wanting to do the similar thing that I want to do albeit he wasn’t using the app but if the USB hub wasn’t powered, it wouldn’t work… As soon a he powered it up, he can play the music
@maurizio_T well, I’m guessing that was the issue. Connected the hub to power and also used a higher quality USB drive. Seems to work just fine once you’ve imported a folder of music or individual tracks into the Files source.
Just make sure your friend with the USB stick has actual music files on there and not just a Rekordbox or Engine library collection.
