- Device model: Macbook Air M3 2024
- Version of operating system: 15.1
- Version of djay: 5.2.5
- Hardware/controllers used (e.g. Reloop Mixon 8 Pro): None
Your question:
Sometimes I need to activate the keylock but when I do so it always sets the original key of the song (0) and not the key at the position of the pitch slider. I thought of some alternative like setting a button that activates the keylock at a pitch close to the percentage of the pitch slider but it can only be activated in steps of 1, which is too much for my case. Is there a way to make the key adjustment in steps of 0.1 or similar?
Any help would be appreciated.
Hi @Manuel_Alejandro, the only way to do this is by disabling Key Lock then moving the Tempo Faders.
Ouh. Ok.
I think another situation where performance is affected is when I’m playing a song with the tempo fader at 3% (or another value) but with key lock off. Then if I want to make a transition by increasing the tempo fader speed (or decreasing it) but without changing the key, it’s not possible. Being at 3% tempo fader, when I activate key lock, the pitch goes to “0”, which sounds weird.
I want to avoid creating a new topic because I have a question related to this one. There’s no way to have a key lock relative to tempo slider position?
Hi @Manuel_Alejandro, currently, key lock is based on the original key of the song and cannot be set based on the tempo slider position.
