Hello,
First of all I have a large library of music - over 50 000 songs. I have so far not been able to get DJay to be able to recognize my entire library so I can easily search for a song when I need it and utilize the library I have. Unless I am doing it wrong, why can I not simply point the file manager at a directory and add my directories of music? I have my music split into a handful of directories for organization…. Most dj apps you can assign a directory and the s/w will scan that directory for any music files. When I am dj’ing and searching for a song I want to do 1 search to find it - not have to try 5 different directories to figure out where it is….Who has time for that will a full dance floor??
Secondly, I tried separately importing the songs by pointing DJAY at the actual files by utilizing “Select All”. This works for smaller directories but I tried one directory (which is not even near the biggest) it has just over 10 000 files and djay basically crashes an cannot select that many files? Has DJjay reached its limit an cannot even scan those files in? If so - that’s brutal! I hope I’m missing something here…. I even tried on the iPad Pro to see if I can go into ‘files” app and “select all” in the same directory in question - and YES it can. So I have to believe the problem or limitation is in DJay. When I DJ - I want to have all my music with me and ready to go. I purchased my music for years and I am not streaming. Some places there is no wifi or cell network at times.
I wish I could just point at my external drive like every other program, it does scan, creates a database - so in the future you can quickly and efficiently recall / search for any song.
If anyone can please offer a solution or insight I would greatly appreciate it! Thank you.
P.S. - I also am used to dj’ing a lot by “play count” as my first go-to. I really wish this would be implemented to sort by Play count.
Thank you!!
Rob
