Issue moving track on cue CDJ2000NXS and NXS2
Hey there. I’ve been using DJay Pro for a couple of years now and I always have the same issue when I connect two CDJ2000nxs or CDJ2000nxs2 on my MacBook Pro. I regularly update OS, DJayPro and drivers. I use to connect both CDJs with an USB connection from each player into the MacBook without an USB hub.
Issue: While one CDJ is playing very often the other CDJ standing by on CUE starts moving the track slightly. The longer the wait the more you’re away from your CUE point. When hitting PLAY during the move it doesn’t start playing. I have to set a new cue point and hit play or give it a push with the Jogwheel.
I´m messing with this issue for years and throughout different MacBooks, Mac OS and DJayPro updates.
Is there a workaround to get this fixed? It must be a common problem as the issue stays with different MacBooks, OS Versions and different CDJ2000nxs and CDJ2000nxs2.
Best regards, Alex
Hi @SOULFLVR, welcome to the Community! Sorry to hear you’re experiencing this issue.
When creating new topics, please do not forget to answer the questions in our template with specific details about your setup not just “iPad” or “Latest Version”. This helps all of our community moderators to provide the most effective support to users with the utmost efficiency.
Since this sounds repeatable, can you please try to capture a short video of the issue, upload it to your Google Drive/Dropbox, enable sharing permissions, then share a link to the video here? Thanks!
