Issue Recording with Reloop Mixon 8 Pro – Mic not included in software recording + long recordings slowed/pitched down
Device model: MacBook Pro (M1, 2021)
Version of operating system: macOS Sequoia 15.6.1
Version of djay: 5.4
Hardware/controllers used: Reloop Mixon 8 Pro
I’m having two major issues when recording my sets with the Mixon 8 Pro in djay Pro:
  1. Mic not included in djay recordings
  • When I plug a mic into Mic 1 on the Mixon, it works fine through the master output (audience hears it).
  • But in djay Pro, if I set the microphone input to channel 5–6, the mic signal doesn’t show up on the meters, and recordings do not capture the mic.
  • From what I understand, the Mixon may only mix the mic at the hardware level and not send it over USB.
  • Question: Is this a hardware limitation, or could djay Pro potentially support capturing the mic signal via USB so recordings match what the audience hears?
  1. Long recordings slowed down / pitched down
  • Short test recordings (1–3 minutes) sound fine.
  • Full set recordings (e.g. 1 hour) come out slowed down and pitched lower, like a sample rate mismatch.
  • My setup: Mic input = 5–6, Recording input = 7–8.
  • I suspect the Mixon runs fixed at 48kHz but djay Pro writes recordings at 44.1kHz, which causes drift over longer recordings.
  • Suggestion: Could djay Pro allow us to set or lock the recording sample rate to 48kHz to match the Mixon?
Overall:
I want to be able to record exactly what the audience hears (decks + mic + FX) directly in djay Pro, without having to route the booth/master into an external audio interface. Are these current limitations due to the Mixon’s hardware routing, or something that could be addressed in djay Pro updates?
Hi @Tiehan_JPG, welcome to the Community! Yes, this is a hardware limitation - the mic channel is handled inside the controller and doesn’t go through djay.
I recommend that you that you use the Mixon 8 Pro in Mixer Mode → Internal with the Default audio settings. You can do this by navigating to the djay Settings>Devices and first selecting External next to the Mixer Mode. Then select the Revert button near the bottom right. This should switch the Mixon 8 back to Internal Mode with the default audio routings. Then try recording again and let me know if that fixes things.
Following up again on my earlier bug report for Reloop Mixon 8 Pro + djay Pro in Internal Mixer Mode. Still unstable after firmware update and full settings reset.
Exact reproduction & current workaround:
  1. My routing:
    • Mixer Mode: Internal
    • Main Output: Reloop Mixon 8 Pro (ch 1–2)
    • Pre-Cueing: Reloop Mixon 8 Pro (ch 3–4)
    • Microphone: Reloop Mixon 8 Pro (ch 5–6)
    • Recording Input: None
  2. When I launch djay Pro, Mic 1 has no signal in the software at all, even though the controller shows it’s active.
  3. The only way to get mic signal:
    • I set Recording Input = Reloop Mixon 8 Pro (ch 7–8) → Apply
    • Now Mic 1 works in djay Pro
    • But recording only captures vocals, no music
  4. So I then set Recording Input back to None → Apply
    • Now recording captures both vocals + music
    • But every time I restart djay Pro, I have to repeat this full toggle process.
  5. Mic 2 never appears in djay Pro under any setup.
Also broken: Mic button LED & MIDI mapping sync
Right now the MIDI mapping is reversed:
  • When I press Mic 1 on the controller, it correctly enables the mic in djay Pro.
  • But when I turn the mic OFF inside djay Pro, the Mic 1 light on the controller stays lit.
  • The two states are completely out of sync.
Request:
Please work directly with Reloop to fix:
  1. The audio initialization bug so Mic 1 stays active on startup without needing to toggle Recording Input.
  2. Add proper USB audio support for Mic 2 so it can be used in djay Pro.
  3. Fix the MIDI/LED feedback so the controller Mic 1 light and djay Pro mic state are fully synchronized — turning the mic on/off on the controller toggles it in software, and vice versa.
This setup is currently unreliable for live streaming and recording. Thanks for looking into this.
Hi @Tiehan_JPG, thanks for the detailed info. Can you please provide your latest setup details as well? Thanks!
Device Model:
Version of djay:
Hardware Firmware Version:
Hi @Tiehan_JPG, sorry for the delayed reply. I spoke with our hardware team and they confirmed that the mic signal is entirely handled inside the hardware. It cannot be routed into djay. This is a limitation of the hardware. The controller doesn’t provide an audio channel to route the mic signal to djay. This is the same for both Mic 1 and Mic 2. I hope that helps clarify things.
