- Device model (ASUS Tuf Gaming FX505DD):
- Version of operating system (Windows 10 Home 22H2):
- Version of djay (5.2.9923.0):
- Hardware/controllers used (Pioneer Dj DDJ-200):
Hello,
I am experiencing an issue with the library view in DJay Pro. In my playlist view, where columns such as Artist, Album, Genre, BPM, Time, and Key are usually displayed, I accidentally made some changes, and now the display is not functioning correctly.
Specifically, when I enable the Key column, other columns (like Artist, Album, Genre, BPM, and Time) are no longer visible. It seems that the Key column takes up all the space, pushing other columns out of view.
Here are the details of the issue:
- I cannot see multiple columns at once; only the Key column is visible when selected.
- I have tried adjusting the column widths and resetting the layout, but the problem persists.
- The issue appeared after I mistakenly altered the column settings.
Could you please provide guidance on how to restore the correct display settings or reset the columns to their default configuration?
Thank you for your assistance!
