Issue with pre-cueing and CFX
MacBook Pro 2021 M1
Denon Prime 4
Sequoia 15.3
Thinking of moving from Serato as there are many features that I like, but came up against an issue when trying it out tonight…
I have enabled the crossfader fx as the mixing between songs whilst changing vocal and tempo is so good. This is where I encountered my issue though. When I cue the next song and I want to listen to it, I can’t hear anything as the ‘effect’ is applied and the crossfader is over the other side. The only way I can get to hear it is if I nudge the crossfader slightly, but then I only hear it with the effect applied, such as only drums or no melody/vocals etc. hope that makes sense!
What I want is to be able to hear the next track ‘normally’ and only way this works is to disable the crossfader fx.
I’m using a Denon Prime 4 by the way.
Hope someone can help!
3 posts were merged into an existing topic: Headphone Cue Not Working with Crossfader FX
Merged with existing topic: Headphone Cue Not Working with Crossfader FX
