Running latest Djay version 5.2.8
Problems
After the deck is touched, the song stops. Like a backspin or just stopping the song totally stops playback and I have to hit play again. When I do, the song starts for a sec and then stops again. Only after hitting play for a second time does the song start.
If two songs are loaded but not playing, and a filter, crossfader or just playing around with any knob will make the song start playing again. It is really random.
iPad Pro 2020 12.9 4th Generation - iOS 18.3
Hi @djcaliente, welcome to the Community! Sorry to hear you’re having issues with the DJControl Mix Ultra.
- Please close djay, turn OFF the Mix Ultra and follow the procedure linked below to perform a Forced Restart of your iPad: Force restart iPad - Apple Support
- After rebooting, go to your Bluetooth settings and make sure no other devices are connected to your iPad.
- Close all other applications on your iPad.
- With your Mix Ultra turned OFF, first launch djay, then turn your Mix Ultra and pair it again.
- If this doesn’t solve your issues, can you please try to capture a short video of the issues, upload it to your Google Drive/Dropbox, enable sharing permissions, then share a link to the video here? Thanks!
Yes!! That worked, thanks!
You’re welcome @djcaliente. Happy to help!
