itunes songs missing ?
played a small family gig yesterday (ipad version) and noticed that songs were missing from the itunes playlist i created, at first i thought it was an itunes issue, (maybe its an issue with loading?) but when i double check using other software the song is there, but in DJAY itunes playlist it was not… anybody else have these issues?
Hi Timothy,
Thank you for your post and I am sorry to hear about this issue.
Can you send us an exemplary track via support@algoriddim.com Subject: “Search String Issue ASSIGN LUKAS E”?
Thank you in advance.
ok so i pinpointed this to a search issue, its tricky, if you type first 2 letters, you can find the song by scrolling all the way down to it, but sometimes if you type the whole title (correct spelling and everything) it wont show up, seems to happen with songs from BPMsupreme?.. hmmm idk…
