iTunes Star Ratings should stay in Sync with Djay’s 'My Collection'
Hi All,
I’d like to suggest an improvement regarding the handling of track ratings in Djay’s ‘My Collection’ after these tracks are imported from iTunes/Music. iTunes is my Master collection and should be the single source of truth.
Unfortunately, it seems that once tracks are added to Djay’s library, their star-ratings become disconnected from those in iTunes and take on a life of their own. This creates confusion and leads to inconsistent information, as the ratings in Djay can differ from those in iTunes, even though other metadata like title and track name continues to sync correctly.
Other prominent DJ software, such as Traktor and RekordBox, offer options to keep star ratings in sync with iTunes/Music libraries. For example, Traktor allows users to right-click on the ‘Music’ icon and select ‘Sync Song Info From iTunes,’ while RekordBox provides a refresh button for iTunes/Music and even a right-click option to retrieve metadata per song directly from iTunes/Music. These features work effectively to keep metadata in sync and avoid discrepancies.
==> So, if you’d also like to see this feature added to Djay, please hit ‘Vote’ in the box at the top left so that everyone who experiences this issue can get a more consistent solution!
This is the Sync-option that Traktor has:
Thanks for the suggestion and detailed explanation @DJ_Big_Blender. I have forwarded this to the dev team for consideration.
To be honest, I’m still not sure whether the star ratings from Apple Music not being imported nor synchronised into Djay’s ‘My Collection’ is a bug or intended behavior.
Could you clarify this, @Slak_Jaw?
See also:
Hi @DJ_Big_Blender, this is unexpected behaviour on djay’s part. Currently what happens when importing to My Collection is that if the ID3 tags of the file contain a rating tag then that takes precedence over the iTunes/Music rating value. So it will work as expected if the audio file metadata tags don’t contain a rating field. I hope that helps to bring some clarity. Also, the team is working on improving this behavior.
Ok, yes, that brings some clarity for me. Much appreciated! It would indeed be great if the team could fix this. However, I’m encountering the same issue with a fresh new file that hasn’t been in Djay yet.
When I drag it into Djay, the rating is empty, even though it is set in Apple Music. So I don’t quite understand how that matches with what you’re saying.
You’re welcome. Thanks for the additional info. That does sound unexpected. Let me pass this onto the team to see what they think…
I’m experiencing the same thing. I was wanting to migrate away from solely using iTunes to manage my library (since Djay Pro doesn’t allow editing of metadata in the “Local Music” section :frowning:).
But I want to be able to use both iTunes and Djay Pro, and just have them share and update common stuff, like it does fine with track titles.
If I add a file with no rating, and then add a rating in Djay Pro, it doesn’t pull through in iTunes. Likewise doing the opposite also doesn’t work.
Edit: On further investigation, they just feel completely unlinked like the Djay Pro rating is its own “special” rating. Other stuff, like comments works fine.
