When I switched to “Jog Pitch Bend” the Wego Jogs work in scratch mode… Nothing change!! Help me, please.
Thanks for contacting us. On the WeGO3, you can pitch bend by rotating the jogwheel on the side (without pressing down).
The “Jog Pitch Bend Mode” setting only applies to controllers without touch-sensitive jogwheels.
Please implement an option to turn off the “touch” mode as well, leaving the jog in only pitch bend mode. Its too easy accidentally touch the top og the jog…
