Jog able to change mode, either Vinyl or CDJ. Vinyl: when u touch the platter will be perform scratch as usual. CDJ: push jog forward as faster the beat and slower down by pull backward. And it does the same thing in waveforms mode. It will be much better than using the small + - button.
Are you using a controller? If so, which one?
I didnt use any controller… What i was actually meant is Djay for iPad itself… Touch the platter to peform beat match or scratch (vinyl or cdj mode).
Thank you
