Jogwheel FLX6 issue
Good day,
I recently switched from the FLX-4 to the FlX-6. Because in the old controller, if I touched the jog wheel lightly from the side, it made the song a little faster or slower. When I touched it at the top, I could either scratch or move the song all the way back or forward, i.e. move it freely.
With my new controller I can no longer do that, I have to pause, and only then can I do the things mentioned and also scratch the song or turn it in the other direction, when it is Paused. How can I change this setting?
Regards,
Mathis
Hi @Mathis_Witt, welcome to the Community! Press SHIFT+JOG CUTTER to enable/disable Vinyl Mode
Thanks, like always, the best and fastest help
You’re welcome @Mathis_Witt. Happy to help!
