When recording a mix, it’s quite frustrating when you mess up the syncing or a simple transition, and so perhaps what would be really helpful and cool, is a button to skip back 30 seconds, deleting that section of the recording and continuing on from there, so you can learn from your mistakes. it is especially frustrating after a long set and ruining a transition of mix without the opportunity to go back and change it…
