When the tempo of the playing music is other than 0.0%, I seems that when jumping to a cue point, it lands slightly off from the cue point.
If I set the tempo to 0.0%, it jumps accurately.
By the way, quantize is turned on.
Hi @Akifumi_Konishi, when creating new topics, please do not forget to fill in the requested information in the topic template:
Please also, capture a video of this issue, upload it to your Google Drive/Dropbox, enable sharing permissions, then share a link to the video here. Thanks!
Hi again @Akifumi_Konishi, can you also confirm if you are using Neural Mix and Keylock when doing this? Thanks!
