I have a reloop mixtour along with a pair JBL 305 MKII running on DJ Pro AI (3.1.4) on MacBook (Catalina). Problem I’m facing is that everytime I want to record a mix, I get to about minute 5 or 6 of the first track playing and then I lose the audio feed first to one monitor shortly after, the second monitor. Audio still comes through on cue to headphones.
I have changed all cables. I have also ran the software without controller and monitors and don’t encounter this problem when not hooked up. I have also updated to the most recent version of DJ Pro.
Any help is much appreciated!
user @Max_Merrifield encountered the same in April 2020 but that thread has no replies and has been closed. @Max_Merrifield , how did you solve the problem of audio dropping out in the middle of your set?
Could you please upload here a picture of your djay PRO AI audio-device preferences? Simply press CMD+"," and go to Devices. Please take a screenshot of these settings. Are you currently running internal or external mixer mode?
Does the audio only stop if you try to record a mix?
What controller are you currently using and what outputs of it are you currently connecting your speakers to?
