Keeps reverting to free trial mid-set
  • Device model: 2020 MacBook Pro M1
  • Version of operating system: MacOS Tahoe 26.6.2
  • Version of djay: 5.6.10
Hardware/controllers used: Custom MIDI controller (Traktor S4 MK3 via HID-MIDI translator software)
This has happened twice already and the one from last night was in the middle of a gig.
Mid-set, all of the sudden the “start free trial” button appears at the top requiring me to “restore purchases”.
Something that may be relevant. I use Djay on two different MacBooks. One for development and the other is my gig laptop. Last night Djay was not open on the dev MacBook (and in fact it was asleep at home).
I was probably about 30-45 minutes into my set on the gig laptop when this happened out of the blue.
Is this expected behavior resulting from two different installs?
Hi @yyz_dj, no, that isn’t expected. You can use a single djay PRO subscription on up to five devices across macOS, iOS, Windows and Android. Your dev MacBook shouldn’t push the gig laptop out of PRO, whether djay is open on it or not.
A few details would help me narrow this down:
  1. Where did you buy the subscription (Mac App Store, iPhone/iPad, Windows or Android)?
  2. Is the gig laptop signed in to a My djay Account? If so, is it the same account on both Macs?
  3. Was the gig laptop online when it dropped (venue Wi-Fi, hotspot, or offline)?
  4. Did Restore Purchases bring PRO back right away both times?
  5. Are both Macs on 5.6.10, or is the dev machine on a different build?
  6. Do you have djay installed on more than 5 devices?
For now, before each gig, open Settings > My djay and check that the subscription shows as active. If it drops again, you can also get to Restore Purchases from that same screen. I hope that helps!
The subscription was bought via Mac App Store.
Actually I just realized that the gig laptop was not signed in to my My Djay account, but the dev laptop is. That might be the reason! I just signed into it now and I’ll see if that fixes it.
For the other questions:
Yes it was online.
Restore purchases worked right away.
Same build.
Djay is installed on both laptops + 1 iPhone + 1 iPad. So 4 total devices.
Hi @yyz_dj, thanks for that. Signing into your My djay Account should do the trick. However, our team would like to look at your account on the back end to see if there might be any other issues.
Please follow the steps below to share your djay User ID:
  1. Open djay Pro on your Mac.
  2. Go to Help > Contact Support.
  3. This will open a page in your browser.
  4. Copy that URL and send it to me via DM (no need to submit the form). This URL contains your User ID so our team can investigate further.
