mac 2.3ghz 8 core
sonoma 14.3.1
djay pro 5.3
ddj400
In Sidebar > Info > (Selected, Active Deck, Deck 1, Deck 2), the key command to load the selected song doesn’t work as expected. When a song is selected in the Info list and the load key command is pressed, focus jumps to the main playlist, and the song from there is loaded instead.
However, other actions from the Info list work fine:
- Add to cue key command works
- Right-click > Load on Deck 1/2 works
- Drag and drop to a deck works
