Key Lock button not changing colour - Android
  • Device model: Oppo Pad Air
  • Version of operating system: Android 13
  • Version of djay: 5.5.1
  • Hardware/controllers used: None / DDJ Wego 4
The key lock button next to the pitch fader used to change colour to blue when you touched it to turn it on but on the new version of djay it just stays white whether its turned on or off.
Key lock still works fine its just the button isn’t changing colour.
Hi @djsmoothe, thanks for the info and screenshot. I was able to reproduce this on Android 15 with djay 5.5.1 as well. I have escalated this to our engineering team for further review. I’ll report back when I have news. Thanks!
Thanks for your quick reply :slightly_smiling_face:
You’re welcome @djsmoothe
Hi again @djsmoothe, engineering has identified the issue and is working on a fix which should be included in an upcoming update (likely 5.5.2). Thanks!
Hi @Slak_Jaw thats great thanks :slightly_smiling_face:
Hello @djsmoothe, djay 5.5.2 was released earlier today and should address this issue. Thanks!
Hi @Slak_Jaw , I’m afraid there seems to be a even worse bug now though after the update! The tempo sliders and bpm are missing from either side of the decks, and they are only visible if one of the middle section options are being used.
Hi @djsmoothe, please make a new bug report topic for this new issue.
Hi @Slak_Jaw , OK I have done it.
Perfect! Thank you @djsmoothe
