Keyboard controls to adjust/nudge the pitch for each deck would be nice
Already there:
You can see the list of keyboard shortcuts available in djay for Mac by selecting “Keyboard Shortcuts” from the “Help” menu.
C’est tres bien, merci!
Is there a way to get both decks sync’ed and reacting to the keyboard speed change?
It’s odd, because I can change the master tempo by holding the tempo slider with the mouse while SYNC is engaged but I can’t do it with the keyboard controls (which is much needed as the mouse control jumps all over the place)
