Keyboard shortcuts revert to default after restarting app
It looks like toggling Enable Keyboard Shortcuts fixed the issue.
  • MBP M1
    Sequoia 15.7.3
    djay Pro 5.6.5
  • PERFORMER FIRMWARE - MACOS V1.2.0.10
    Rane Performer 1.3.0.13
  • customized keyboard shortcuts revert to default after restarting
  1. Add a few custom keyboard shortcuts. Select done. They work fine. Rename and mark done. they work fine.
  2. Restart djay
  3. keyboard shortcuts return to default
  4. Can reselect my keyboard shortcuts set , select done and they work fine until next app restart.
C) EXPECTED RESULTS:
  • Custom keyboard shortcuts set act as the new default on app restart.
D) ACTUAL RESULTS:
  • keyboard shortcuts return to default on djay restart.
Notes: I believe this was happening with djay Pro 5.6.4 as well. Same behavior with and without controller plugged in.
Hi @ben446, Thanks for the details about the issue and your setup - this is very helpful. We were able to reproduce this and our dev team is investigating further. I’ll report back here when I have more news.
Hi again @ben446, I just wanted to follow up and confirm that engineering has identified the issue and is working on a fix which should be included in an upcoming update (likely 5.6.6). Thanks!
Hi @ben446, 5.6.6 is being released today and should address this issue. Thanks!
