Kicking a dead horse...
Please offer the original djay 1 app again. Money is not the issue but my OCD is. I have several iDevices, however the only one I own that will fit into the iDJ Pro iPad slot is the original iPad 1. Please??
Hi Benjamin,
have you tried using an 30 pin to lightning adapter like this one:
http://www.apple.com/shop/product/MD823AM/A/lightning-to-30-pin-adapter
I think that should solve your problem.
Thank you for the follow up, I see where the problem is. Nevertheless we can not provide djay 1 to users which did not purchase the app when it was available. I hope you understand.
Yes sir, the 30 pin/lightning adapter works fine with the iPad mini or iPhones. The iPad 1 however is originally a 30 pin design. The issue I’m having isn’t being able to hookup to the iPad but it’s the iOS versions that are or aren’t compatible. Thank you.
