Ive been using Djay pro for years without any problems but have a new macbook and now getting lag after about 4 hours of using the software.
It’s fine up until then, but then the controller gets really laggy.
I DJ weddings so I need it functioning for 6-7 hours which never used to be problem.
This has now happened with Djay Pro 2 last week, so I switched back to Djay Pro 1, but had the exact same issue.
I’m not sure what it could be.
My setup…
- Macbook Pro 2017 retina (USB-C ports) - Mojave - 16 gig - 1 TB space.
- Pioneer Wego3
- External hard drive with my music on it
- Djay Pro 1 & 2
My previous Macbook was 2015 with the standard USB ports, and also had Mojave.
Never had any lag issues with it.
Because the new mac needs usb-c, I have the usb-c to usb adaptor for my external hard drive, and also an adaptor for the cable that runs from the wego3, to the macbook. (usb-b to usb).
Would getting a USB C to USB B cable would improve performance, rather than using the adaptors?
Any ideas on what is causing the lag after 4 hours?
Please help!! Thank you in advance
