Device model (e.g. 2020 iPad Air 4th Gen):
Mac Mini M4 2024
Version of operating system (e.g. macOS 14.4.1):
15.5 (24F74)
Version of djay (e.g. 5.1.2):
5.3.1
Hardware/controllers used (e.g. Reloop Mixon 8 Pro):
DDJ-FLX4
Summary of the issue:
Sound drops for a few milliseconds
How to reproduce the issue:
Dont know, it comes and goes.
Hi @Johan_Rosenberg1, thanks for the details about your setup and the issue. Can you please try updating to 5.3.3 and let me know if the issue persists? If so, please capture a short screen recoding and share it here. Thanks!
Nope it didn’t help, i think it happens to seldom for a screen recording to make it clear why it happens…
Hi @Johan_Rosenberg1, you could try the following process to reset the iCloud state:
- Quit djay.
- Make sure you have a backup of your djay Media Library.djayMediaLibrary file on an external drive or in the cloud.
- If you have previously disabled iCloud for djay Pro in System settings, please make sure it is re-enabled for djay Pro. https://help.algoriddim.com/hc/en-us/articles/360014702832-How-do-I-enable-iCloud-syncing-on-iOS-and-macOS
- Open the app Terminal.app
- Run this command:
defaults write com.algoriddim.djay-iphone-free CMCResetCloudKitState -bool true
- Launch djay
This will reset the cloudkit state and should clear up the issue. After this, it’s recommended that you leave iCloud sync for djay enabled to prevent caching of Cloudkit and the growth of the djay Media Library.
Here is a copy of the sample from activity monitor.
Thanks for the sample @Johan_Rosenberg1. I’ve passed this onto engineering for review. In the meantime, can you please try using a different, high quality USB cable to see if that solves the issue? You could also try a different USB port on your Mac Mini. Also, if the issue persists, can you please try to capture a screen recording of it? Thanks!
