Hello i am a Deejay 2 user in an iPad Air 2. In your last updated i have noticed 2 important changes:
The precueing method is different, in the version before you have to pulse the song for a while and it stars to play, now you have three dots on the right córner of the song and when you pulse the songs starts to play. This is a bad improve because when you search a song in the search box you cant do the precueing because the dots dont apears, you have to put in a deck to do the precueing.
now the gain buttom doesnt works!!
Please, can you help me? I think that you have 2 importat bugs on the last version.
Thanks for your feedback Oscar and apologies about the delay in getting back. The team has already been investigating this very issue and found a solution. We are releasing an update within the next days which addresses the gain and precue issues specifically.
Thank you for your support. I will be waiting for the next updated. Deejay2 is the best application for Ipad that i have ever tried, and i have tried lot really. Please, dont change the functions that works right now only improve the ones that not.
